If you didn't check the Z axis parts during the preflight check then you should do it now or you may have problems during this chapter.
Make sure you have removed the original lead screw covers as specified in the preflight check and disassembly guide
Screw the Bear z_leadscrew_caps on both motors.
Insert 2x M5x10 screws in the z_motor_mount.
Thread 2x t-nuts on the M5 screws (1-2 turns) and place them vertically.
Repeat with the remaining z_motor_mount.
Make sure this section is clean of dust, it will be used as reference for the z_motor_mounts.
Slide the z_motor_mount from the top of the frame, slotting the t-nuts into the extrusion channels. Note the orientation, the hole for the Z smooth rods should be to the outside the frame
Tighten the M5x10 strongly.
Slide the Z motors in the z_motor_mounts. The motor cable should be oriented towards the inside of the frame (red lines on the images).
Secure the Z motors in place with 8x M3x10 screws (reused from your original Prusa). Press the motor in the direction of the yellow arrows while tightening the screws evenly, incrementally and in turn.
If you are using the Bear X axis or the Original Prusa MK2(S)/MK2.5(S) X axis, you will need to unscrew the smooth rod tensioning screws, as shown (by approx. 2mm).
Bear extruder and X axis (BearExxa), BearMera of Bear X axis with Bondtech extruder: release tension using the belt tensioning screws.
Original Prusa MK3(S): remove the 2x top motor screws and release tension of the screw on top of the arm. Then rotate the X motor.
Original Prusa MK2(S) or MK2.5(S): remove the 2x top motor screws and rotate the X motor.
Place the X axis on top of the Z lead screws. Carefully rotate, by hand, both Z lead screws to engage with the nuts and move down the X axis.
Continue to rotate both Z lead screws until you can align the top X smooth rod with the bottom of top Z axis extrusion.
Very gently, insert the two Z smooth rods (320mm long) into the bearings and down to the Z motors. The smooth rods must be fully inserted. They must touch the Z motor body itself (you can hear a "metallic click" when you reach the motor).
Insert 2x M5x10 screws in one of the z_top.
Repeat with the remaining z_top.
Install the z_tops on top of the Z axis. T-nuts must go into the extrusion's grooves and the smooth rods in the smallest of the two front holes.
You must press down the z_tops until the smooth rod is touching the top of the hole.
Make sure the z_tops are parallel to the top of the extrusion
Tighten the 2x M5x10 screws.
Reinstall the extruder on the X axis by following the external guide(s) relevant to the extruder and X axis of your choice:
BearExxa (Bear extruder and X axis): start with 3. Extruder, then 4. Extruder and X axis assembly up to step 10 and finish with 5. Final adjustments and calibration up step 8.
BearMera (E3D Hemera): start with 3. BearMera extruder up to step 14, and then 4. Adjustments.
Bondtech on Bear X axis: follow our guide here.
Original Prusa extruders installation guides: MK3S+, MK3S, MK2.5S, MK3 (spiral wrap), MK3 (textile sleeve), MK2.5 (spiral wrap), MK2.5 (textile sleeve), MK2S.
Bondtech extruder on original Prusa X axis: choose the guide corresonding to your extruder on support.bondtech.se/c/Prusa.
Congratulations you have finished this chapter :)
Go to the next chapter: 07. Heated bed.
