i am disassembling an HP Laser Jet Pro 400 MFP M425dn printer.
crwdns2933315:02crwdne2933315:0 crwdns2934263:01crwdne2934263:0 |
Paper feed issues, what to replace |
crwdns2933315:04crwdne2933315:0 crwdns2934263:01crwdne2934263:0 |
Duplexing jams every time |
crwdns2933315:02crwdne2933315:0 crwdns2934263:00crwdne2934263:0 |
After replacing rollers & pads still getting 'No paper in pickup' err |
crwdns2933315:04crwdne2933315:0 crwdns2934263:00crwdne2934263:0 |
How do I fix these sleep issues? |
Windows users will have the most drivers available.
For Linux, you have two driver choices:
Note: Most Linux distros include HPLIP in the default package set. Some distros do not (or use an old version), but it can be updated/installed if either is the case.
If you can use the HPLIP driver, it is better than the generic driver. While most distros support HPLIP, you may need to use the generic driver on distros that do not.
Note: This feature was removed in a later firmware update. DO NOT update the firmware if you use it! It has not been used in the HP JetIntelligence printers since day one - HP no longer maintains it. Modern printers use HP Smart or 123.hp.com today and no longer include drivers on a (outdated out of the box) driver CD.
HP Smart Install has been abandoned by HP and removed in later firmware releases. Part of the reason for this is that the drive stored on the printer was difficult to update and required regular firmware upgrades (not provided by HP), as the files were in a protected EEPROM, which was integrated into the base firmware and not split to allow updates.
As a result, this driver was always outdated and was best ignored in favor of downloading drivers online. This feature was abandoned by HP a few years after it had failed and never tried again.
If you use Linux or do not need it, removing the feature with the newer firmware is generally better. It seems like a “downgrade” to remove, but it improves the printer. CAUTION: Once removed, the HP Smart Install "feature" CANNOT BE RESTORED!
HP Smart Install is known to cause problems in Linux. This primarily happens on old builds registering the printer as a USB mass storage device. While it was fixed years ago, it can still cause problems in current releases if left unpatched.
Since this is a known issue primarily affecting Linux, removing the "feature" with later firmware is strongly recommended for Linux users. However, once it is done, there is no way to revert.
This printer ships with an 80A toner cartridge, which gets ~2,600 pages. Once you wear out the original 80A, seriously consider the 80X. Unlike the 80A, the real-world yield is far closer to the HP estimate (~6,900 pages for the 80X),
Setting the printer to Continue or Prompt before the toner runs out allows you to run it like an old-school laser, albeit with nags. This can be done once the printer runs out of toner if you want to wait to set this, but the default out-of-toner setting (Stop) should be changed, especially if you monitor the print quality. Setting the printer to "Prompt" adds a nag every few pages. Setting the printer to Continue ignores the chip with a permanent "Black supply very low" nag.
Note: Some tweaks are intended for the 80A to improve the average page per toner lifetime before they run out. These work on the 80X, but are less effective.
Less Paper Curl
While not required, this will reduce the fuser operating temperature (and lifespan). However, if the printer does not ignore the setting, this may need to be re-enabled for heavy cardstock (100-120lb) due to fusing temperatures needed. Do not enable this on printers used for cardstock regularly.
Override out (HP 80A/80X)
To configure the printer to ignore the chip and keep printing, do the following:
Low threshold (HP 80A)
While this setting does not prevent the low toner message from coming up on your printer, this will allow you to defer the low toner nag.
To change the low threshold on the printer from the 15% default (8-10% is recommended), do the following:
Note: If you change this setting below 10%, you run the risk of the waste toner filling up and potential toner replacements due to the waste toner compartment being too full. As such, DO NOT apply this to printers with the 80A cartridge. It works fine with the 80X cartridge, but this is because of the bigger waste toner compartment.
WARNING: CHANGING THIS REDUCES REMAINING PAGES WHEN OVERRIDE OUT KICKS IN!
Resolution/ReT (HP 80A/80X)
This can be done on the printer or in the driver with a print mode to lower the resolution. The downside of each method is as follows:
Print Density (HP 80A/80X)
By default, this is set to 3. Changing this to 2 will not noticeably impact the print quality and will reduce your toner consumption. To do this:
Quiet Print Mode
The main benefit to enabling this is extended engine life since the printer will reduce the printing speed. Print speed WILL be reduced.
The design on the M401 (and M425) does not work well with some anti-snag Ethernet cables due to the port door making access tight with horribly designed anti-snag covers. There are three solutions to this problem:
crwdns2936753:07crwdne2936753:0 42
crwdns2936753:030crwdne2936753:0 161
crwdns2959996:0crwdne2959996:0 14,451
