Apple hardware test Failure code...
After running a aht it gives an error : 4SNS/1/40000001: VP0R-0.000
what is the exact problem in this logic board. System is very slow . i already dismantle 3-4 times some time after assembly it works for little time means working until restart. after restart it again giving same problem.
If i Plug the Charger in then the laptop works fine no problem. while on charger also AHT gives same error . What to do??
I see two possibilities; use it as is, or, replace the logic board.
What did you do in the end ? I have exact same problem. Dont no weather to get fixed or not ?
Run the extended version of the Apple Hardware Test. Sometimes you will get an error if you run the quick version, and it may be something of a false positive. Some have found doing an SMC reset 3 or 4X can eliminate the error (note: a work around not a fix). If it is indeed a logic board error it points to a sensor(s) failing, VPOR might be VGC(VPU) related. You'll probably need a new logic board, AFAIK sensors as well as the VGC are soldered to the logic board which pretty much makes them non-DIY repairs, as soldering on logic boards are not for amateurs.
If this answer was helpful please remember to return an mark it Accepted.
i already done SMC or PRAM, can you locate the specific sensor which creating this problem ? thanx in advance
Nope - looked but "best guess" was all I could offer.
it was the error of sensor on the logic board . i replaced the logic board
SIMRAN crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 6,623
