Run the extended version of the Apple Hardware Test. Sometimes you will get an error if you run the quick version, and it may be something of a false positive. Some have found doing an SMC reset 3 or 4X can eliminate the error (note: a work around not a fix). If it is indeed a logic board error it points to a sensor(s) failing, VPOR might be VGC(VPU) related. You'll probably need a new logic board, AFAIK sensors as well as the VGC are soldered to the logic board which pretty much makes them non-DIY repairs, as soldering on logic boards are not for amateurs.
If this answer was helpful please remember to return an mark it Accepted.
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
4
If i Plug the Charger in then the laptop works fine no problem. while on charger also AHT gives same error . What to do??
crwdns2934271:0crwdnd2934271:0 SIMRAN crwdne2934271:0
I see two possibilities; use it as is, or, replace the logic board.
crwdns2934271:0crwdnd2934271:0 originalmachead crwdne2934271:0
What did you do in the end ? I have exact same problem. Dont no weather to get fixed or not ?
crwdns2934271:0crwdnd2934271:0 Raymond Moran crwdne2934271:0
