Repair information and guides for the CDMA version of the fourth generation iPhone. Model: A1349 / 8, 16, or 32 GB storage capacity
Where do I clean if I got finger oil on my parts?
I had my iPhone into a shop for repairing when my power button failed. After I got it back, I have very bad bluetooth reception and almost non-existent WiFi. I remember that the shop did not use gloves. I took it back there and they are denying all responsibility.
So I assume that there's probably some finger oil on various parts and I've seen all of the suggestions on here about cleaning "all contacts" with a degreaser or Windex. But I don't know what "all contacts" are. Can someone help me out and point them out?
Any help?
Thanks, Brett. I didn't check this until after I left work so I will try on Monday when I have access to my Pentalobe screwdriver.
Hey Snowdog,
This is a pretty common problem, and you're correct about the finger oil causing bluetooth to fail.
There are a couple places that you should clean the contacts before re-assembly. While many of connectors in the iPhone use plug-and-socket connections, many just use spring pressure contacts. These pressure contacts are those which you should clean off. Here are a few:
Use some isopropyl alcohol or some Windex on a Q-tip or microfiber cloth, and you should be golden.
Good luck, and let us know how it turns out.
crwdns2886500:0iPhone 4 Power & Lock Buttoncrwdne2886500:0
crwdns2930805:0crwdne2930805:0
iPhone 4 Power & Lock Button Replacement
crwdns2934079:0crwdne2934079:0
crwdns2937803:0crwdne2937803:0
15 - 30 minutes
crwdns2886500:0iPhone 4 Verizon Power Buttoncrwdne2886500:0
iPhone 4 Verizon Power Button Replacement
snowdog850 crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 1,698
