Repair information and guides for the CDMA version of the fourth generation iPhone. Model: A1349 / 8, 16, or 32 GB storage capacity
Wont charge after screen repair
I replaced the touch screen and back panel. The iPhone worked fine before it just had a cracked touch screen. after replacing the broken screen the phone works great however, it wont charge or recognize itunes when plugged into the computer. I have power cycled the phone, opened it up again and made sure all the connections are clean and plugged in properly and it still wont charge. If the phone is off when I plug it in it will turn on but wont show that it is charging. The only thing I can guess (after looking online) that is wrong it a fuse may have blown during the repair. When I removed the batter the first time I did notice a tiny spark by the connection, but I could see no damage and the phone works properly in all aspects except charging.
Any suggestions?
crwdns2889612:0crwdne2889612:0 -1
Sparks are never good. Possibly a solder pad lifted between the battery connector leads and the Logic Board. If this is the case it could be a simple solder job, or a very complex procedure with bypass wires needed.
Double check that your dock connector is plugged in all the way. Here is a link to the dock connector guide.
i've got the same problem - replacement screen worked fine after the repair but when the battery ran down it just wouldn't charge. Usual sign when I switch on of low battery and insert charging cable screen, but nothing happens when I insert th cable - have checked the connections and they all seem fine and I was careful when I disconnected the battery.
Very annoying - any tips welcomed....
Clark crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 4,521
