The Craftsman Pressure Washer 580.752050 is a gasoline-powered device designed for medium to heavy-duty cleaning tasks, capable of outputting a maximum pressure of 2550 PSI with a flow rate of 2.3 gallons per minute. This website contains repair and more information about the product, including its Briggs & Stratton 126T02 7hp OHV engine, axial cam pump, and additional features such as a 30 ft steel-braided high-pressure hose and four quick connect spray tips.
Oil plug where is it
Where is the oil drain plug located at?
Hi @jakewalpole
There is no oil drain plug per se in the washer.
The way to drain the oil is to tip the machine (away from the spark plug) and drain it out of the oil fill/dipstick tube.
See p.19 of the owner manual for how to change the oil.
Jake Walpole crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 129
