crwdns2935069:02crwdne2935069:0
580.75205
Background
The Craftsman 2550 PSI Pressure Washer, model number 580.752050, is a gas-powered device produced by Sears, Roebuck and Co. This model is designed to output a maximum pressure of 2550 PSI and has a maximum flow rate of 2.3 gallons per minute. The pressure washer is powered by a Briggs & Stratton 126T02 7hp OHV engine and has a fuel tank capacity of 1.6 quarts. The device is equipped with an axial cam pump with a thermal relief valve. The pressure washer is designed to be mobile and weighs 72 lbs.
The pressure washer is equipped with several features to assist in medium to heavy-duty cleaning tasks. It has a 30 ft steel-braided high-pressure hose with quick connect ends and an ergonomic spray gun. The unit also includes four quick connect spray tips (0°, 15°, 40°, soap), and an onboard 1-gallon detergent tank with a control valve. The pressure washer utilizes ReadyStart technology to provide easy starting of the Briggs & Stratton engine. The device is designed with large wheels and a fold-down handle for ease of movement.
Technical Specifications
  • Model Number: 580.752050
  • Product Type: Pressure Washer
  • Maximum Pressure: 2550 PSI
  • Maximum Flow Rate: 2.3 GPM
  • Engine: Briggs & Stratton 126T02 7hp OHV
  • Displacement: 190cc
  • Fuel Tank Capacity: 1.6 quarts
  • Pump: Axial cam pump with thermal relief valve
  • Power Source: Gasoline
  • Weight: 72 lbs
Warranty
The Craftsman 2550 PSI Pressure Washer (Model 580.752050) is protected by a one-year warranty provided by Sears. This warranty covers any defects in both the materials and workmanship of the product. If the pressure washer is intended for commercial use, extended coverage is available. To claim the warranty, you should refer to the operator's manual for comprehensive details. It should be noted that proper maintenance requirements should be adhered to, as outlined in the manual, to avoid any complications in claiming the warranty.
Craftsman 580.752050 Owners Manual
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2942667:0crwdne2942667:0 900
