Released on June 23, 1996, Model NUS-001, 64-bit gaming console
crwdns2934591:0114crwdne2934591:0 crwdns2934593:0crwdne2934593:0
Why Does My N64 Only Show Some Games On My TV?
Hi Guys.
I just brought out my Nintendo 64 today and found a problem.
Only some of my small collection of N64 Games worked.
The console (PAL) switches on and all the wires are good i also have an expasion pack in the console. My TV is a new Samsung HDTV.
The games that worked were:
Donkey Kong 64
Golden Eye
Diddy Kong Racing
The Games that didn't work:
Super Smash Bros
Mario Kart
Super Mario 64
I am not the most technical. Could those games be broken? Have i got a missing acessory?
Thanks!
N64 games often refuse to work after accumulating even the tiniest bit of dust, which is especially likely after a period of storage.
Clean the contacts of the games that don't work by first removing any dust & dirt with an air compressor, and then cleaning the metal contacts with some Isopropyl alcohol (as close to 100% Isopropyl as you can get.)
crwdns2942205:01crwdne2942205:0:
...and here is the guide for cleaning the slot. Start with that first.
I had this problem as well with the same games not working! I made sure they were all immaculately clean and still no dice. BUT I FIGURED IT OUT! Basically, I noticed that it was mostly older games that weren’t working. I was hooking my n64 directly into my hdtv’s AV port. On a whim, I plugged an old dvd/vcr in to the AV port on the tv, and plugged my n64 into the dvd/vcr and PRESTO! GAMES WORKED! Not sure what the technical explaination for this is, but it has been foolproof! Good luck!
Switch to another older TV and it worked great! Ty you all!!!!
I guess the AV plug on 64 units are not compatible with on the newer TVs. Will need to use a older tv or some type of conversion will need to happen. I went through the whole process of cleaning the cartridges and cleaning the cartridge slot. Still only one game work When I switch to a older TV all the games worked. Kids are happy.
Euan crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 6,769
