A portable beginner sewing machine with a sturdy metal frame and a front loading bobbin.
Why does the machine get stuck?
When i try to use it the needle gets stuck inside the bobbin case. The bobbin case doesn’t work and is stuck
I cleaned out the bobbin case and have put everything back as the diagram and the top thread gets tangled and the needle won’t come up
=== Update (05/08/26) ===
How do I fix it
@audreyjoyc49032 are you having the same problem with your sewing machine as the OP (Original Poster)? What make and model is your sewing machine?
check witch way bobber is put in, they do have a timing belt. does it do it on straight stich
Pooja shrestha crwdns2934231:0crwdne2934231:0
crwdns2959996:0crwdne2959996:0 290
