crwdns2933307:0crwdne2933307:0
Specifications:
  • Stitch Applications (57) - A Stitch Application simply means a specific sewing technique that you can do with a selected stitch. Basically, Stitch Applications are all the different things you can actually DO with your machine!
  • Built-In Stitches (6) - Choose from a variety of stitches for basic sewing, decorative sewing, and more.
  • Four-Step Buttonhole (+) - Buttonholes are sewn in four easy steps, clearly displayed on the Stitch Selector Dial.
  • Front Loading Bobbin (+)
  • Darning Plate (+) - Place the darning plate into position over the machine's feed teeth, which prevents the feed teeth from coming in contact with the fabric. Use this for free-motion sewing like stipple quilting, monograms and even for sewing on buttons.
  • Easy Stitch Selection Dial (+) - Built-in stitches are displayed on the Stitch Selector Dial. Simply turn the dial to select the stitch you want to sew.
  • Reverse (Lever) - Sew stitches in reverse, usually done to secure a seam at the beginning and end to prevent unraveling.
  • LED Lighting (+) - Long lasting LED lighting provides bright illumination and stays cool to the touch.
  • Free Arm (+) - Slide off the Removable Storage Compartment for access to the free arm, making it easy to sew trouser hems, sleeve cuffs and other smaller or tubular projects.
  • Snap-On Presser Feet (+) - Presser feet can be easily removed and attached when needed for various sewing techniques.
  • Extra High Presser Foot Lifter (+) - Presser foot has an extra high position available to accommodate thick fabrics.
  • Sewing Space (Needle to Tower) (5.6") - The distance between the needle and the main part of the machine. Having a generous "C" space allows you to sew larger projects like quilts with ease.
  • Bobbin Class (15 Transparent) - SINGER or INSPIRA branded bobbins are recommended for best results.
  • Machine Size (13 x 7 x 11.5)
  • Machine Weight (10)
  • Amps (0.6)
  • Watts (72)
crwdns2935291:0crwdne2935291:0
Dana Norby
crwdns2935283:007/13/22crwdne2935283:0
125 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
crwdns2936753:07crwdne2936753:0 35
crwdns2936753:030crwdne2936753:0 167
crwdns2959996:0crwdne2959996:0 3,194
