Having trouble removing sd card
Hi @robertkalfus
What happens when you gently push in the SD card and then release it, does it spring back a bit further than what it was before you pushed it in?
It should spring back just enough for you to use a fingernail to prise it out from the slot i.e. card is no longer flush with the case
