My screen is showing no signal and do not start
i started my pc then it showed that no signal found try to move your keys or mouse but it wonn't still start
Try a full power refresh and check if that resolves the problem.
Here’s the procedure:
When the battery is out, check its voltage. If it is <2.5V DC or if the battery is >4-5 years old, replace it. The battery model number is stamped on the battery e.g. CR2032 etc.
If it starts, there may be a message about the date and time being incorrect. This is normal as the above procedure has reset the BIOS back to its factory defaults. Once the date and time have been adjusted, the message won't appear the next time the PC is started. Any user defined BIOS settings that have been altered by you to suit your particular operating requirements will need to be changed back also.
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 26
