Repair guides and support for gas and electric hot water tanks, boilers and household heat exchangers.
tabodd 16l gas water heater
hi .my water heater will not ignite automatically. if i turn on water and then turn on heater it ignites .but if i switch if i turn on water while its on it will not ignite. also if i leave it turned on with water off it tries to ingnite.the lcd stays on also .be great and much appreciated if anyone can help
Hi @rob85574
What is the model number of the water heater?
Hi jay model number ABC123 thats all it has on it
Hi @rob85574
If this is the heater it may be a TABODD JSD16L but I can't find a user or service/parts manual for it.
You said "....i turn on water and then turn on heater it ignites...". Usually with instantaneous gas water heaters they need water to be flowing through them first before they ignite, so as to prevent damage to the heat exchanger in the unit. So this appears to be working OK
If it tries to ignite without any water flowing it could be a faulty flow sensor that is used to detect that the water is flowing through the heater - sticking perhaps.
Does altering the water regulator setting affect its operation? Is the water supply pressure to the heater sufficient?
no dosnt make a difference. flow sensor deffo a good start .limescale here not great.i thought it was ignition swith as if i turn it on it tries to fire .i will look at the flow sensor see if i can clean it .many thanks
rob crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 45
