I need password system bios
I'm trying to types password is rejecting and I'm trying to
Set up and to boot menu is all rejecting
I am going to expand on @dinoo_fixit's answer as they missed key details. When you get the master password, it's case sensitive. On the D series and early E series machines you enter it and press Shift+Enter, then it gets you past. However, you need to go into the security menu, put the master password in the administrator password box and leave the other boxes blank - this will clear it out. Once you do that, save the changes and exit the BIOS.
Thanks, this should be the accepted answer
It is a very old laptop, first of all disconnect/reconnect CMOS battery for an initial reset (Dell Latitude D630 CMOS Battery Replacement) and then use a tool like this (https://bios-pw.org/) to insert serial number/asset tag and get a recovery password
BIOS battery hasn't worked since the C6XX series. Master password is the only way.
crwdns2936751:024crwdne2936751:0 13
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 15
