Wash/Drain cycles work but no spin!
Everything works in wash cycle properly and drains and the nothing happens other than a loud intermitent clicking sound that seems to come from the lid lock?
Hi @timgrose,
Not sure if a calibration will work on your model. According to the tech sheet (see p.4 in tech sheet below) it only applies to models that do not have level selection. The owner manual for your model shows that you can select the soil level i.e. light, medium or heavy.
Could be a shifter fault.
Here's the tech sheet for the washer.
Go to p.2 to view the procedure for how to activate the diagnostic test modes and check what error code is being displayed.
There's a Fault/error code method display chart on p.3 that shows how to interpret the status lights to work out the code.
If it is an F7 E5 error go to p.7 to see the possible cause and what to check.
If you find the problem and it is a faulty part that needs replacing, Here's the parts list that is useful. Locate the wanted part in the list and note the part number that is shown with it. Search online for the part number only, to find suppliers that suit you best.
If you search on YouTube for (insert wanted part number) replacement, sometimes if you're lucky there are videos that show how to remove/replace the part.
Thanks Jayeff...Here are Codes I got (in order starting with Dial on Rinse):
F5 / E3 F5 / E2 F7 / E6 Everything points to Lid Lock switch and since the motor works fine with agitating clothes CW & CCW...it makes sense that the F7 E6 indicates an open circuit to the motor due to the Lid Switch. Am I correct?
Not sure if the lid lock shouldn't also stop it agitating as well. I thought that if the lid lock is not showing closed and locked it shouldn't even start
Perhaps try the Lid lock tests as shown in Test #8 on p.18 then you'll know for sure.
crwdns2942667:0crwdne2942667:0 26
Hi @timgrose
What is the model number of the washer?
crwdns2934271:0crwdnd2934271:0 jayeff crwdne2934271:0
Kenmoore 1105142510 I installed brand new Actuator and that changed nothing. I read of performing a recalibration when installing a new component in this series...is that true and I will attempt that today. Not optimistic that will work :)
crwdns2934271:0crwdnd2934271:0 Tim Grose crwdne2934271:0
