Explore repair and more information about the Craftsman 315.119100, a portable power drill/driver. Equipped with a 19.2 Volt DC motor, adjustable speed and torque, a 1/2 inch keyless chuck, and a built-in LED work light, it caters to a range of tasks.
Replacement for LI-ION 19.2 Volt battery No. 130156001
None of the available replacement batteries indicate that they specifically replace my original 130156001 battery for use in my 315,119100 drill and 259260 charger. Is there a suitable replacement that works with my drill and charger ?
@jerrymarti13575 these batteries should all be interchangeable. Craftsman 19.2 Volt batteries 11374,11375, 11376,1104511375, 120235021,130156001, 130279003, 130211004, 130279005,130239006,130235021, 1323903, 1323513, 1323517, 130211002,130211022, 130211030, 130279017, 315.11448, 315.101540, 315.113740,315.113753, 315.11375,315.114852, 315.1144850 , 315.114852, 315.114480, 315.11485, 315.115410, 315.PP2010, PP2025, PP2011, PP2030. Of course, that is what some spreadsheet says. Always verify this with a potential seller.
Do a search for a replacement battery by the power drill number vs. the battery part number. You will most likely still find replacement batteries for it.
If you can't source a proper battery then I suggest that you rebuild your battery by replacing the cells. Not a terribly complicated or difficult job. Of course, there are also rebuild services around that will do this task for you.
Jerry Martin crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 163
