crwdns2935067:01crwdne2935067:0
315.1191
Background
The Craftsman 315.119100 is a portable power tool designed for drilling and driving tasks. It was manufactured by Diehl Mfg Co for Sears under the Craftsman brand. The drill driver operates on a 19.2 Volt DC motor and features a variable speed reversible (VSR) switch that controls the speed according to the pressure applied on the switch trigger. The no-load speed ranges from 0-440 to 0-1,600 revolutions per minute (RPM), depending on the setting of the two-speed gear train, which can be set to either low (1) or high (2) speed.
The tool comes with a 1/2 inch keyless chuck, allowing for quick hand-tightening or release of the drill bit in the chuck jaws. It has a 24-position adjustable torque ring which can be set to deliver the right amount of force for different applications, with a maximum torque of 340 in.lb. The direction of rotation selector, located above the switch trigger, facilitates changing the direction of bit rotation. This drill driver also includes a built-in LED work light for better visibility, a battery gauge to monitor the battery level, and a bit storage area on the base of the tool. A built-in level on the top of the motor housing helps to keep the drill bit level during use.
Technical Specifications
  • Coupler: 1/2 in. Keyless
  • Motor: 19.2 Volt DC
  • Switch: Variable Speed Reversible (VSR)
  • No Load Speed: 0-440/0-1,600 r/min. (RPM)
  • Clutch: 24 Positions
  • Torque: 340 in.lb.
Warranty
The warranty for the Craftsman 315.119100 is a one-year full warranty. If the tool fails to provide complete satisfaction within one year from the date of purchase, it can be returned to any Sears store, parts and repair center, or other Craftsman outlet in the United States for free repair. If repair proves impossible, a replacement will be provided. However, if the tool is used for commercial or rental purposes, the warranty only applies for 90 days from the date of purchase. It is important to note that this warranty grants specific legal rights and there may be additional rights that vary from state to state. In case of any warranty claims, it is advisable to contact Sears, Roebuck and Co. in Hoffman Estates, IL 60179.
Craftsman 315.119100 Owners Manual
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2942667:0crwdne2942667:0 606
