Repair and disassembly information for the Google Pixel Tablet, Google's first tablet under the Pixel line of devices. Designed to be both portable and used within the home with the included charging speaker dock. Released June 20th, 2023. Identified by model numbers ‎GMD6Z or GTU8P.
Does this screen need to be replaced?
I wonder if this screen might be able to be repaired, and not necessarily replaced. Would it be worth it to take it off and reattach it to see if that fixes the problem, before I buy a new one?
Hi @scottvandekrol
Damaged (cracked) LCD screens cannot be repaired, they have to be replaced.
Here's the ifixit Google Pixel Tablet Screen Replacement guide, that shows what to do.
thanks @jayeff. Just to clarify, I don't see any cracks on the screen, and thought maybe it might just be a loose connection?
@scottvandekrol
The screen's internal connections are a matrix arrangement of vertical and horizontal lines.
Loose connections result in black horizontal or vertical lines not curves.
Run your fingers very lightly across from a coloured section of screen to the black and check if you can feel a difference at all.
If you can't feel anything most likely it is internal damage that you can't see.
Scott Vande Krol crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 127
