Why is flashing the light
When I. Open the door the light starts flashing
Jacob, can you include the model number of your refrigerator?
For sure Jerry dff100c1wdb
Hi @jacobarenas
Check if the evaporator unit inside the freezer compartment at the back behind a panel (access to the panel is though the door at the front) is iced over.
If it is then there's a defrost problem with the refrigerator.
This could be due to a faulty defrost heater p/n C1414.4.3, a faulty defrost thermostat (aka thermal fuse) p/n C0472.4.4/BD, a wiring problem for the defrost circuit, a faulty defrost control board or the drain tube leading from below the evaporator unit in the freezer to the drain pan underneath the compartments, near the compressor may be blocked.
Let us know what you find.
Jacob Arenas crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 564
