Repair guides and support for gas and electric hot water tanks, boilers and household heat exchangers.
Leaking Heat pump water heater, AO Smith HPTU-50N130
Chris Stillman
***1 minute ago
UPDATE: The leak is coming from the bottom device. I'm looking into this manual if that pulls out, etc. Any input is welcome.
Hello, I woke up to a nice puddle of water underneath the water heater. It is spraying water out from the inside. The water is literally spraying out from behind the section in the photo attached.
I may be in over my head on this one but figured I'd check in with you guys!
Thank you!
PS, water and power are off.
@chrisstillman
How old is the unit?
According to the brochure there's a 10 year "limited" warranty on the heat pump.
Might be worth checking to see if it's covered if <10 years old.
Here's a service manual that may help.
See the section about changing the element.
To order parts you may have to use this link
Yes sir! Thank you again! My wife and I are going bonkers trying to find receipt. It's under 5 years old, never mind ten!
I'll get back to you as I learn some things, etc. Thank you again!
@chrisstillman
See if this is applicable to your model.
Chris Stillman crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 84
