The Empire is variously referred to as a record player or 6-in-1 media center - or some recombination. One model is: VTA-270B (A)
My turntable is slow
Hi all I've had my turntable now for about 2 years, hardly used it tbh. I've more recently been using it but it's has started being slow. I have took the table off cleand the belt and and removed any excess grease and it's perfect for about 5 mins and then it going slow again. Any ideas... maybe the belt ?
It sounds more of a lubricant issue here as the bearings build friction and then get tight. Type spraying some WD40 into the tables bearings and the motor axial as well. These o,d units often have a speed regulator either friction or a centrifugal governor. See if they are clean nd might need lube as well.
Mattyw04 crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 14
