Repair guides, disassembly, and troubleshooting information for the Nintendo Switch 2, the successor to the original (2017-2021) Nintendo Switch consoles. Announced January 2025, and officially released on June 5th, 2025.
Can the switch pro 2 controller be repaired?
Unlike the original switch pro controller, the switch 2 pro controller doesn't have any apparent screws on its surface. Is it possible to open it to change the battery, or to replace joysticks should they fail?
Custom labels for clothing are essential for any brand looking to make an impact. Our woven labels for clothing provide style and durability, Custom Woven Labels
Hi Miel!
Yes, you can replace the battery and joysticks. But the joysticks are most likely soldered on the motherboard (like the 1st one).
Most likely held by plastic clips first, when removed it should reveal the screws.
Did not received a broken Nintendo Switch Pro 2 controller yet, when I received one, will make some guides :). But this can take some time..
I found a teardown of the controller on by devJack on StackerNews. They're using a RKJX2 variant from Alps Alpine, which are designed very much like those in the JoyCons, that connect to the board using a ribbon cable.
So they're not soldered and should be "easily" replaceable, and I really stress that easily as it seems you need to remove the faceplate which is held on with plastic clips & adhesive to get to the screws to even take the controller apart. And it assumes the sticks are replaceable with off the shelf standard RKJX2 which has extra plastic near the cable side the variant in the controller doesn't have (hard to tell if this will impede anything from the pictures).
That is some great info!! That they are not soldered on means that the repair will be WAY easier. The only thing is that (as predicted) you need to remove the front plate. But again, this will not be that difficult.
Custom labels for clothing are essential for any brand looking to make an impact. Our woven labels for clothing provide style and durability, Custom Woven Labels https://austintrim.co/woven-labels/
miel crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 88
crwdns2942667:0crwdne2942667:0 1,338
