Apple’s new format for the 14 lineup features a 6.7-inch OLED—like the Pro Max—but the same features as the iPhone 14 with a dual camera setup and the Bionic A15 chip with a 5-core GPU.
Panic full error code 0x500000
Hi there. My iPhone 14 Plus keeps rebooting every few minutes. Error code is 0x500000.
Can anyone shed some light on what this issue is and what I need to do to get it resolved
Can you post the full panic, just so I now I've got it right? A screenshot. Or other. If you can?
I don’t know how
{"bug_type":"210","timestamp":"2025-06-01 03:31:27.00 +0100","os_version":"iPhone OS 18.5 (22F76)","roots_installed":0,"incident_id":"7B5557D5-5C52-444A-9BD1-E26BE033DC4B"}
"build" : "iPhone OS 18.5 (22F76)",
"product" : "iPhone14,8",
"socId" : "8110",
"socRevision" : "11",
"incident" : "7B5557D5-5C52-444A-9BD1-E26BE033DC4B",
"crashReporterKey" : "4db0141a5734c630d1219f5206225807486278c8",
"kernel" : "Darwin Kernel Version 24.5.0: Tue Apr 22 20:37:55 PDT 2025; root:xnu-11417.122.4~1\/RELEASE_ARM64_T8110",
"date" : "2025-06-01 03:31:27.66 +0100",
"panicString" : "panic(cpu 3 caller 0xfffffff04a0340f0): SMC PANIC - ASSERT: target\/d28\/target.cpp:266: 0, SMC BSC failure, spreadsheet ver(*10) 40\nS.sensor array 0 - 4 is 0x0, 0x500000, 0x0, 0x0, 0x0 \nF.sensor array 0 is 0x0\n\n - Misc(2) OUTBOX1 not ready\nASSERT: target\/d28\/target.cpp:266: 0, SMC BSC failure, spreadsheet ver(*10) 40\nS.sensor array 0 - 4 is 0x0, 0x500000, 0x0, 0x0, 0x0 \nF.sensor array 0 is 0x0\n\n\nRTKit: RTKit-2784.122.1
[code]
release - Client: AppleSMCFirmware_H14-5204.122.2.d28.REL\n!UUID: c46e970d-3534-3c09-aaa4-fe87887c49f7\nASLR slide: 0x0000000000000000\nTime: 0x00000011ec22aa2c\n\nFaulting task 2 Call Stack: 0x000000000003fbc8 0x000000000003f584 0x000000000003f390 0x000000000003dddc 0x000000000002eb28 0x00000000000348e4 0x000000000003b7a4\n\nChinook ASC Async error info: \nl2c_err_sts 0x5000fbfc00000000, l2c_err_adr 000000000000000000, l2c_err_inf 000000000000000000\nlsu_err_sts
[/code]
Async error info: \nl2c_err_sts 0x5000fbfc00000000, l2c_err_adr 000000000000000000, l2c_err_inf 000000000000000000\nlsu_err_sts 000000000000000000, fed_err_sts 000000000000000000, mmu_err_sts 000000000000000000\ndpc_err_sts 000000000000000000\n\nMailbox (0): (0)\n Inbox AKF_KIC_INBOX_CTRL = 0x00020001, AKF_KIC_MAILBOX_SET = 0x11111101\n Outbox AKF_AP_OUTBOX_CTRL = 0x00020001, AKF_AP_MAILBOX_SET = 0x00000000\n\n dir endpoint timestamp msg\n ==== ============ ================== ==================\n [RX] user01 0x00000011ea643f7c 0x4251583100004013\n [TX] user01 0x00000011ea644878 0x0000000000004000\n [RX] user01 0x00000011ea64523c 0x4251583100085010\n [TX] user01 0x00000011ea6459b4 0x000010b000025000\n [RX] user01 0x00000011ea646860 0x4249535300006013\n [TX] user01 0x00000011ea64715c 0x0000000000006000\n [RX] user01 0x00000011ea648144 0x4249535300087010\n [TX] user01 0x00000011ea648a70
Hi Liza,
You were on the right track with error code . Here's the smoking gun from your panic log.
Alisha, who asked you about it previously, is the author of the best information we have on iPhone panic log errors. Here's what their wiki page has to say about yours.
iPhone SMC Panic Assertion Failed - iFixit
Sensor Array: 0x500000
Likely Issue: Battery **
**Replacing the battery will result in a warning message that the battery installed is not an OEM Apple battery, unless you use an Apple battery supplied by Apple's Self Service Repair program and run System Configuration.
The short story is your phone is having an issue talking to the battery. It scans its sensors every three minutes, so three minutes after booting it goes to check. In your case for some reason it can't talk to the chip on the battery so it reboots the phone in an attempt to recover. Of course this is a hardware failure, so once it comes back up an checks the sensors again, it sees that it can't talk to the battery so it reboots the phone... and just keeps doing it because despite how smart a computer can look, it's really stupid and will never ever realize that rebooting again won't help.
So the fix here is to replace your battery. If you buy a genuine Apple battery and have iOS 18 then you should be able to get rid of the "genuine parts" warning using the Repair Assistant; otherwise you'll either have to pay Apple to fix it or live with the warning.
Here's the iFixit guide showing you how to do that repair if you decide you want to tackle it yourself.
iPhone 14 Plus Battery Replacement - iFixit Repair Guide
actually secondhand batteries would work as well. It's going to show as "used" in the parts and service history, but it won't have any compatibility issues.
crwdns2947721:0crwdne2947721:0
crwdns2947633:0crwdne2947633:0
Liza crwdns2934231:0crwdne2934231:0
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 43
crwdns2936753:030crwdne2936753:0 178
crwdns2942667:0crwdne2942667:0 178
