Released by Motorola in Q2 2023, the Edge 40 Pro—sold as the Edge+ (2023) in the U.S.—is the brand's flagship model in the slab form factor. It is powered by a Qualcomm Snapdragon 8 Gen 2 chipset with 8–12 GB of RAM, 256–512GB of onboard storage and a 6.67" 165Hz pOLED display.
Tempered glass camera lens cover
I dropped my phone and the tempered glass camera lens cover cracked extensively. I went to cut away the cracked part with a diamond cutting wheel in my Dremel so I could use the camera. I ended up finding out that this glass cover is just a stick on piece with the adhesive around the perimeter of the lens cover. I was able to remove the entire cover to keep using the camera. All I need is a replacement stick on glass lens cover. Is this something I can purchase somewhere?
Same here in need to find the part
@rickfrerecend Did you read the previous answer that includes at least two links to that part?
I have three places I can generally find something like this; Amazon, eBay and AliExpress.
First I'd like to clarify about your lens. The ones I'm familiar with have a little glass circle within each of the camera lenses, surrounded by a bezel. As you've found, replacement is simple; just pry out the old glass, clean the old glue and stick a new piece of glass in.
Yours seems to be a little different. From what I can see, it looks like it's one molded piece that covers all of the cameras and flash rather than individual circles of glass. Here's a picture from an AliExpress listing for your phone that seems to show what I'm talking about.
If that's right then the associated listing should get you what you're looking for; apparently it comes in black or blue to match the back of your phone.
Rear Back Camera Glass Lens For Motorola Edge 40 Pro Edge+Plus 2023 Moto X40 5G Replacement+Adhesive Sticker XT2301-5 XT2301-1 - AliExpress 509
Here's pretty much the same listing on eBay.
2pcs New Rear Back Camera Glass Lens For Motorola Moto X40 edge 40 Pro Edge+ 5G - eBay
I will likely order from one of these vendors but I was just wondering if the original part, which is tempered glass, would be available from Motorola. It seems to me that something like this would be available. Anyway, just curious.
Thank you
@rogercheros I'm not up to date on the availability of parts directly from Motorola, but my guess would be that if anything is available, it would most likely be that you would have to buy the entire rear panel. I could be wrong, though.
Roger Cheros crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 200
