Repair guides and support for motorcycles manufactured by Yamaha Motor Company.
solenloid decompression problem. Solved!
Road Star XV 1700 2006, solenloid pushes the two rods in, but valve does not stay open to decompress. Anyone an idea ? Cheers. Two days later : After opening up the crank-carterI, I found one of the two rod- levers was slightly bent, so it didn't push in the decompression-rod enough to engage the extra crank-opening-moment of the exhaust-valve.
So if changing the starter-motor, start-relay and decompression-solenoid don't resolve the problem, take out the engine oil, then take of the crank-carter and check if the two rod-levers push both rods in ( equally ).
kees van schaik crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 11
