Repair and troubleshooting information for the FixHub Power Series | Portable Soldering Station, the combination of the Portable Power Station and the Smart Soldering Iron. Released in October 2024.
Temp control not showing on firmware 1.2.2
I just received my soldering station and noticed that what I can do in the console seem more limited than I expected. Currently I can only see the status of the battery, what's connected to the USB ports, see serial number, reset battery status, and update firmware. I've attached an image of what my interface looks like and how I think it should look based on some sleuthing online. If the console still a work in progress or should I be seeing more, such as temp control?
So. I think I see what's going on here.
Your options is the top window and expected is the bottom one? Right?
The top screen shot is the Fix Hub power station. The bottom screen shot is the Fix Hub itself (the soldering iron). Since the power station has a display on it where the temperature can be adjusted, the console is not needed to do this, unlike when you use the iron alone.
In order to see these settings, you need to connect the iron to the computer directly. (I can actually tell even from your screenshot that you don't have an iron connected either. It shows nothing in either USB port on the Power Station). Mine even showed that the firmware on my iron was too new for my Power station when I had it connected.
Isaac R Slayton crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 34
