The Xiaomi Redmi Note 8 is a mid-range smartphone by Xiaomi released October 2019. It has a 6.3" IPS LCD display, a 48 MP main camera, a rear-mounted fingerprint sensor, a 4000 mAh battery, and runs on a Snapdragon 665.
Hp tidak lama hidupnya dan hilang sinyal
Ketika hp dinyalakan dan membuka aplikasi hp langsung off dan kemudian ketika dinyalakan kembali tidak bisa.. Butuh charger untuk menyalakannya dan itupun sulit sekali.. Ketika hp dapat dinyalakan tidak ada sinyal dan tidak bisa wifi
Translation Indonesian - English
The phone doesn't last long and the signal is lost
When the phone is turned on and the application is opened, the phone immediately turns off and then when it is turned back on, it doesn't work. It needs a charger to turn it on and even that is very difficult. When the phone can be turned on, there is no signal and it can't use WiFi.
@rakaputrap36927 the very first thing you want to do is to replace the battery. While at it, I would also recommend to replace the charging board. it is not very expensive and will rule out any issues coming from that, since it also has the antenna connection. After that re-evaluate and see what you got. Here is the guide for the battery Xiaomi Redmi Note 8 Battery Replacement and for the charging board (Daughterboard, Sub_Board), use this guide Xiaomi Redmi Note 8 Screen Replacement starting at around Step 15.
Translation
@rakaputrap36927 hal pertama yang ingin Anda lakukan adalah mengganti baterai. Saat melakukannya, saya juga merekomendasikan untuk mengganti papan pengisi daya. Biayanya tidak terlalu mahal dan akan mengatasi masalah apa pun yang muncul karena biaya tersebut, karena papan pengisi daya juga memiliki sambungan antena. Setelah itu, evaluasi ulang dan lihat apa yang Anda dapatkan. Berikut panduan untuk baterai Xiaomi Redmi Note 8 Battery Replacement dan untuk papan pengisi daya (Daughterboard, Sub_Board), gunakan panduan ini Xiaomi Redmi Note 8 Screen Replacement mulai dari sekitar Langkah 15.
crwdns2886500:0Xiaomi Redmi Note 8 Batterycrwdne2886500:0
crwdns2930805:0crwdne2930805:0
crwdns2934079:0crwdne2934079:0
crwdns2937801:0crwdne2937801:0
45 minutes - 1 hour
crwdns2886500:0Xiaomi Redmi Note 8 Screencrwdne2886500:0
1 - 2 hours
raka putra prayoga crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 40
