Model A2159, EMC 3301. A refresh of the entry-level 13" MacBook Pro. Available in Silver and Space Gray. Released July 2019.
New battery shows normal but not charging
  • I replaced the battery with an I fix it replacement but the battery is NOT charging
    • Battery shows up in System Info
    • Health = Normal, 52% charge
    • Mac shuts off when unplugged
    • SMC/NVRAM resets did nothing
Update (05/24/25)
I opened it up and reseated the connections and it is still not working. Here is the coconutbattery window
Check the BMC cable is properly connected and the ZIF connector latch is set.
You may want to install this gem of an App as it offers more useful info CoconutBattery snap a image of the Apps main window posting it here so we can see things.
I responded but it didn't add it under your comment?
@brandons73519 Try to edit the main question and add the CB image to there. From what I can see of the image everything seems to be OK.....
@brandons73519 - mmm... The battery appears to be working and the battery is in need of a charge, it does look like the batteries temp is a bit high. Let try this shut the system down fully and disconnect the charger, let it set for a while to cool down . Now plug the charger back in and restart the system and quickly reopen CoconutBattery take note of the batteries temp and not if the battery is charging looking at Charging With it's currently zero are we getting a higher value now hopefully enough to charge the battery.
Brandon S crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 54
crwdns2942667:0crwdne2942667:0 54
