Why is my keyboard light not coming anymore?
My keyboard light is not coming on anymore. May I know the reason?
Just verifying that you tried pressing Fn + Spacebar keys (both together) a few times to step through the various backlight setting options .i.e. off, low and high, is this correct?
If it still doesn't work try pressing the Ctrl + Spacebar keys (both together) and check if that works.
The shortest thing that can work for you is Try Fn + Spacebar first. If that doesn’t work, update drivers or check BIOS.
Well check for the setting may be you accidentally turned off or a driver issue. Sometime outdated driver or missing driver can also be the reason for this issue so will suggest you to check your keyboard driver and make sure that it is updated to it's latest version.
crwdns2942667:0crwdne2942667:0 153
