Known as either the KitchenAid Mini or the KitchenAid Artisan Mini, this compact 3.5-quart tilt-head mixer is ideal for small batches and limited spaces. It comes with a 250-watt direct current (DC) motor and a Flex Edge flat beater with a rubber edge that scrapes the sides of the bowl. The Artisan Mini is slated to be discontinued in 2026
ksm3316x stops on STIR setting
I turn it on to STIR. It runs smoothly for a few seconds and then stops. It runs well and smoothly at other speeds so I suspect it is not a damaged gear. Why would it come to a stop so soon after starting cold.
If your KSM3316X stand mixer runs fine at other speeds but consistently stops shortly after starting on STIR, it’s almost certainly an electrical or control board issue, not a mechanical one. The STIR setting uses lower voltage and torque, relying more heavily on the governor or phase control board to regulate power. A failing governor, faulty phase control board, or worn carbon brushes (less likely but possible) can cause the motor to cut out under the low-load condition unique to STIR. Cold start issues point to failing electronic components that stabilize as they warm up at higher speeds. I’d bet on the phase control board; swap it out first.
David Abineri crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 113
