Announced on October 13th, 2020, the iPhone 12 mini is a smaller version of Apple's iPhone 12. It features a 5.4-inch OLED display, an A14 Bionic processor, and dual rear cameras.
Little metal pin broken off
Hi everyone.
I found out today that a small metal pin on the bottom of my iphone broke off. It doesn't seem to affect the phone at all, but can someone explain to me what it's for?
I can see that it was supposed to touch a dot on the back of the screen.
I have marked the small metal pin in yellow at the bottom of the phone.
I hope you can help me answer this question, thanks
That is a chassis grounding strap which via its spring action connects to the back of the display assemblies back panel offing both a static and EMI pathway to the main case. As long as the second tab is not damaged I think you'll be OK. Otherwise you'll need to replace the speaker unit.
Thank you very very much!
The other strap is fine.
Again thank you for your answer
@rasmushenn39758 - If you're set, don't forget to accept the Answer. Thanks!
Rasmus Henningsen crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 30
