Repair and disassembly guides for Epson printer. The company was founded in 1942 as Daiwa Kogyo, Ltd., but merged with another company in 1959 to create Suwa Seikosha Co., Ltd.
Why does my glossy photo paper have vertical creases?
When printing on glossy paper, it has these crease lines. I never noticed it when printing on normal paper or cardstock.
Are you running it through a top-feed or bottom-feed printer? I’ve seen that before on multiple bottom-load Epsons with mid-weight photo paper. Even 65-lb cardstock will do it, so it's a mechanism flaw on bottom-feed units. There is no fix; it's a limitation of the machine.
To avoid that, you really need a machine with both a top and bottom feed for heavy to mid-weight photo paper, as the top feed doesn’t crease photo paper like a bottom feeder will.
This is why true “photo printers” (ESPECIALLY the ones with photo grade color sets) have both, or are top only. Epson has moved to having both on a lot of the newer photo grade units, especially the ET-8500/8550 generation where you have trays for mid weight paper, and a top feed for rigid stocks - the 8550 even supports 13x19 posterboard in it's top feeder, so that gives you an idea what they can do with that configuration and heavy papers. Even the ET-15000 and the EcoTank Pro lineup is going hybrid. Any of these bottom feeders are either a few years old or were always cheap affairs from when they were new. Any of the more current "Claria HD" cartridge based machines even went hybid - Epson used to do one or the other for years, but they offered both on anything respectable for a few years.
Sam crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 73
