Repair for cars and trucks manufactured by German automaker Mercedes-Benz.
Everything is going wrong with my w205
I bought a used C200 w205 2019
It started with falts active break assist esp
And every time I leave the car to cool down and when I start it there is no messages
Later I found that every time I turn left while am using the break it show me this messages
Additional messages came after that starting from check engine then the gearbox stop turning from whatever am using P, D or R and after several times of waiting for about 10 min or so the gearbox work good then I get a wipper malfunction or light malfunction
But also every time in the next morning the car work fine and I went to the work shop and after running the diagnos program, he told me that I need to replace my stearing column sensor or rage and if I couldn't find it e can repair it
So what should I do and is what he is saying is right and can be fixed because I can't find the replacement in Egypt
You need codes. These Benzes aren't parts cannon cars. Get a proper all system scan done, and get a copy of the report, or buy a proper scanner which can do it. You can use something like an Xtool or Autel, but no generic scanner is going to cut it on a German car.
Actually i can program that with my system,the ABS could be faulty
Saher Abd El.Aziz crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 59
