Subaru introduced the "New Age" Impreza to Japan in August 2000. Larger in size compared to the previous iteration, the sedan increased its width.
What’s wrong with my brake lights
My brake lights are not working on my 2002 Also front passenger side low beam light is out I replaced the brake light switch 4 times 3 times it has melted.and I cant figure out how to replace the low beam bulb 4/24/2025
Hi @colettelosoya
Here's a video and an image from the owner manual that shows how to replace the headlight bulb and what type of bulb is required. There is no separate low beam headlight bulb. The headlamp bulb is a dual filament type bulb i.e. low and high beam light combined in one bulb
(click on image)
If the brake light switch is burning out this means that too much current is flowing through the switch when it is operated, causing it to heat up and eventually fail.
Do all 5 brake lights work after the brake light switch has been replaced i.e. 2 brake lights each on the left and right side rear of the vehicle and 1 centre high mount brake light in the middle? If they do, is one brighter than all the rest? The centre high mount light won't be quite as bright as the other four which should all be the same brightness.
If none are working after replacing the brake switch, disconnect (unplug) all of the brake lights and then reconnect one brake light at a time and check if it lights OK when the brake switch is operated. You may need two people to do this to make it easier to do.
If it does, reconnect the next one and check. Keep doing this until either all the brake lights are working or if you connect one and then you find that no brake lights are working anymore, most probably it is a faulty bulb in the last brake light that you connected.
Colette Losoya crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 44
