No power after PSU replacement
Hi,
I've got a iMac that doesn't power up. I open it up and I noticed the diagnostic LED don't lit up and according to other guides if the LED 1 doesn't lit up means that the motherboard don't get a proper voltage feed from the PSU. I checked the voltages with a DMM from PSU and there was no voltages coming from the PSU either connected or disconnected from the motherboard. So I thought the problem was the PSU and I ordered a new PSU from ebay and replaced it.
At first I checked voltages of the new PSU before connecting it to the MB and were right. I connected it to the MB and checked again and everything seems right again and the LED 1 lit up (according to other guides this is how it should be). Then I tried to power up the iMac but suddenly the LED 1 turned off without any other sign of "life".
After few attempts pressing the power button, connecting and disconnecting the AC plug, disconnecting the power button from the MB and trying to power it up shorting the power connector leads, now when I connect the AC plug the LED 1 lit up for less than 1 second and then turn off and the iMac won't turn on in any way.
At this point I suppose the MB is dead. If any of you can confirm this or give me some other suggestion it will be really appreciated.
Thank you a lot.
You have a short within the logic board. Carefully take it out and do a detailed inspection for burnt or discolored components. By chance what was done to the system before you replaced the power supply? It's possible that was the cause of the short.
Hi Dan,
Actually I though about that. I did not take the logic board out but I have carefully and gently bend it enough to do a fast inspection with a flash light, especially around the logic board power connector but I did not see anything strange or burned component. When I will have some spare time, I will take the logic board out for a deep inspection.
Before I replaced the power supply the system was off for a long time as it would not power up, unplugged from AC. When I got it I have removed the display and I noticed all diagnostic LED were off. Reading the guide explaining what the LEDs means, I supposed that would be the power supply board and I replaced it. The rest is written above.
I have also changed the 3V backup battery as the system was off for few months.
Thank you for your answer.
Eugenio crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 43
crwdns2942667:0crwdne2942667:0 43
