The iO, released in 2020 is an electric toothbrush by Oral-B. It is able to connect to your smartphone via Bluetooth and gives you realtime 3D teeth tracking. Identified by type number 3758. Models include: iO Series 7, iO Series 8, iO Series 9, and iO Series 10.
display not working anymore
I have this issue...my toothbrush io 9 display has stoped working but everything else working fine....i open it an and found water inside...this could burn the display? can it be fixed?
In my case, the battery leaked and damaged the circuit board. I had to repair one of the traces because it was corroded, and the display is working again. I also protected the board with electronics varnish. I replaced the battery and glued the damaged seal around the toothbrush neck.
cristian crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 84
crwdns2959996:0crwdne2959996:0 478
