Hi @dancing1020
Check if the drive belt has moved and is rubbing the belt guard and causing the noise.
If it is this could be caused by a loose nut on the yellow transmission drive pulley causing it to wobble slightly, causing the belt to move position.
Here's a video that shows how to replace the drive belt which will allow you to check if all is OK or not
Hi @dancing1020
Check if the splines on the clutch assembly are stripped.
Here's a link with a video that may help.
If it is search online for W10721967 to find suppliers that suit you best.
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
crwdns2944067:04crwdne2944067:0
Checked, belt looks good and belt guard looks fine too. No vibrations, just very noisy.
crwdns2934271:0crwdnd2934271:0 Dancing1020 crwdne2934271:0
Clutch looks okay, washer makes no noise on wash cycle it’s only loud when spinning.
@dancing1020
Not the belt or the clutch that only leaves the transmission or the motor
crwdns2934271:0crwdnd2934271:0 jayeff crwdne2934271:0
My Kenmore washer is doing the same thing
crwdns2934271:0crwdnd2934271:0 John Adams crwdne2934271:0
