Why is my washing machine so loud?
I have a Whirlpool WTW4816FW1 top load washer, it works but it has became very loud on the spin cycle.
The washer has been doing this for a few months now.
Does anyone what the issue can be? There are no vibrations, it’s just really noisy.
crwdns2944067:04crwdne2944067:0
Checked, belt looks good and belt guard looks fine too. No vibrations, just very noisy.
Clutch looks okay, washer makes no noise on wash cycle it’s only loud when spinning.
@dancing1020
Not the belt or the clutch that only leaves the transmission or the motor
My Kenmore washer is doing the same thing
Hi @dancing1020
Check if the drive belt has moved and is rubbing the belt guard and causing the noise.
If it is this could be caused by a loose nut on the yellow transmission drive pulley causing it to wobble slightly, causing the belt to move position.
Here's a video that shows how to replace the drive belt which will allow you to check if all is OK or not
Update (04/15/25)
Hi @dancing1020
Check if the splines on the clutch assembly are stripped.
Here's a link with a video that may help.
If it is search online for W10721967 to find suppliers that suit you best.
Dancing1020 crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 45
crwdns2942667:0crwdne2942667:0 45
