Screws inside display won‘t grip
Hi,
for whatever the reasons the screws inside my display (picture attached) have become loose. They wont grip when trying to screw them back in.
However, when screwing them in without the top part (so just directly into the bottom) it works. So it seems to be a length issue.
Is there anything i can do?
They are the original screws…
Update (04/15/25)
This is the screw: its T8, I think 4mm in length and 2mm in diameter.
crwdns2944067:05crwdne2944067:0
[image|3615014][image|3615013]
This is the screw: its T8, I think 4mm and 2mm in diameter.
crwdns2934271:0crwdnd2934271:0 Carl Fischer crwdne2934271:0
I would just order a set from both models & hope one of them will do it... I think the screws you pictured are 4mm long threads & 5.3 in total including the head (maybe wrong). I would give it a go at least. Failing that then we have to look for another screw that will do it....
crwdns2934271:0crwdnd2934271:0 livfe crwdne2934271:0
https://www.amazon.de/dp/B07JQ99YPW I just ordered this set, I hope it helps.
Thanks for the help!!
@carl_jfischer Good, has many choices in there, one must do it, good luck!
Works very well (almost too tight) with m2.5x6mm screws. Thanks for the help!!
