Repair, disassembly, and troubleshooting information for the Steam Deck with LCD display, a handheld gaming console made by Valve, released on February 25, 2022. Identified by model number 1010.
Joystick Replacement "sticking" before install
My Steam Deck joystick replacement (part number 34F7AJB0000) arrived in a plastic bag, and the stick was forced to the right while inside the bag. Once removed from the bag, I gave it a test to make sure it was okay. The joystick "sticks" in place when pushed all the way in any direction. I have to give it a little nudge to get it to return to the center. This is prior to it being installed.
Is this normal behavior? I don't want to go through the effort of installing it if it's defective.
Well, it depends on what brand and which console. My Xbox's controller joysticks, for example, would also be stuck when I take it off and push it to the limit. That's because there's an area that the joystick wouldn't be able to reach because of the casing, and taking the casing off had caused it to go past its usual limit and as a result it became stuck. For Steam Decks, I'm not really sure if the same thing would happen, but it is a possibility that the plastic bag had damaged them. I'm afraid you would have to install them and test them again. It might just because the joysticks were pushed past its normal limit.
Also, try lubricating it with a drop of mechanical oil, and see if the result is better.
Peter crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 61
