Nintendo's upgraded version of the Nintendo 3DS. It features bigger screens, longer battery life, better pixel density, and a better design.
old 3DS XL keeps shutting down after closing normally
i got my 10+ year old out my basement in 2023 worked perfectly fine till almost 1.5 mouth ago,so the problem is the when I close the 3ds xl it goes in to sleep mode then I put it in my pocket later on when i pull it out its shut down
(seem to happen when shook roughly or somthing)
That might be caused by corrosion at the battery contacts. Check whether the area around the contacts have any signs of weird liquid stains, and if there is clean with an isopropyl alcohol wipe. If there's rust, you might want to get some sandpaper and gently rub the contacts so they would work. If the corrosion is on the motherboard, take it off and use a toothbrush dipped in isopropyl alcohol to brush at the corroded area and hopefully it won't be a problem anymore.
Nintendo 3DSs will also shut down if it did not detect the upper half's cables and components(3d slider, speaker, camera, screens). If the cables are broken, then it might work for a while and shut down randomly. Or it could be poorly connected ZIF cables or broken connectors that temporarily disconnect when you shake it. You should probably take the motherboard out and check for both corrosion and broken ZIF connectors, and when you're putting it back together make sure to connect the cables properly. If the problem still persists, then the flex cables are probably broken. Get yourself a new 3d slider cable and see if it works.
T Mizell crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 56
