2 screws that hold headlight housing is stripped
I need to replace my headlight bulbs but the 2 screws holding them in are stripped. What can I do to get them out
What year is this on? Most of the time you shouldn't need to remove the whole assemblies to swap bulbs out. If your two bolts are out in the open, you can use what's called an extractor socket to bite into the head of the bolt to pull it out then replace the bolts. You can also try tapping on a socket smaller than the initial bolt size, metric or standard and seeing if that will bite, but I would recommend using an extractor socket.
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 63
