The Sony Cyber-shot DSC-W190 is a 12.10 Megapixel camera with a 3.00x zoom. It was first introduced in July of 2009 along with the DSC-W180. The Sony W190 is close related to the W180 model. Only difference is that the W180 has a lower sensor resolution.
Camera fails to open during power on
sony dsc-w190
title. when i turn on the power the lens extends, then makes a terrible noise, followed by an error to the screen "turn the power off and on again".
@loganmcalpine that very much sounds like a stuck lens which is one of the most common errors on digital cameras. Start of by trying to fix this with the few tips that are listed on here I found that most often the lens is actually damaged and requires a replacement.
Use the Sony DSC W180 W190 Level 2 Svc Man to disassemble your camera and to either work on the lens (replacement parts are a bit difficult to obtain) or to replace it. It is not to complicated and lenses should still be available. It's a great little camera and a worthwhile fix.
While you work on your camera, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Logan McAlpine crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 75
