Samsung Galaxy A50 not charging
Firstly I cleaned the charging port still not charging, shows the charging sign but it doesn't charge secondly tried different charging cables still not charging. Finally came to conclusion to change the charging mother board on a whole new charging mother board the phone still wont charge.It also has a top speaker not working have to put phone on a loudspeaker when on a phone call. First cleaned the speaker still not working what could be the problem.
@nonjabulo the A series has issues with the flex cables coming from the charging board to the main board. Check that for micro tears and corrosion and proper connection to the boards.
Next follow the Samsung troubleshooting flowchart for the not charging
Use the A50 Component Layout and your PDF readers search function to locate the component to check (i.e. C9030) on your main circuit board. Measure the values listed and replace/repair as needed.
This is for the charging only. Once we got this done we can check on your speaker
NONJABULO crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 113
