Explore comprehensive repair and disassembly guides for a wide range of food-cooling appliances. This is your go-to solution for troubleshooting and fixing refrigerators, fridge-freezers, and other cooling units. Whether you're dealing with common issues or looking for step-by-step instructions on specific models, our detailed guides cover everything you need to keep your appliances running efficiently. Perfect for both DIY enthusiasts and professional repair technicians.
Mini Refrigerator light overheating melting plastic light surround
My mini FRESTEC refrigerator lightbulb is super hot and melted the plastic surrounding the light and turned brown from overheating?
This question was migrated from https://meta.ifixit.com/Answers.
Hi @sarahbell
What is the model number of the refrigerator?
Was the lightbulb the original that came with the refrigerator or one that has replaced the original.
If it was a replacement is the correct wattage lightbulb being used?
Perhaps check if there's a visible door switch in the door jamb of the refrigerator i.e. door operates switch. If there is then with the refrigerator door open check if when you manually operate the door switch that the light turns off, just in case the light is on all the time when it shouldn't be.
Sarah Bell crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 22
