How to fix back this cable so it can function again?
It looks like it was originally soldered to the casing.... I guess it is a bit of a no brainer?
That’s the Bluetooth antenna cable which is a connected to a thin strip of metal underneath the Optical Drive, near the slot. It’s glued on to the uppercase.
Yes, but is it a single wire only or are there 2 in the casing? (it looks soldered)
@livfe - The COAX cables shield is connected to the case, the inner wire is soldered to the metal plate.
@danj A 'Simple' soldering job then.....
@livfe - Compare with a second system where it goes as the placement is important.
@danj I know roughly where it goes to, I will work it out, just wanted to know if I just solder it back on in the same place that was all.... could have been a simple answer rather than a long discussion ;) I can compare with another but I don't wanna take out all the stuff to see it ..... end up breaking another the way things have gone today :)
livfe crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 69
