Repair information and guides for the minor refresh of the Late 2018 MacBook Air, with the same model number (A1932) and EMC number (3184). This model features a True Tone display and a slightly revised battery.
Why does my MacBook have no sound?
Hello
I have a Macbook Air 2019 Model A1932, and the speakers just doesn't wan't to work.
I've tried alot of things to get it back working, yet it's still not working.
  • Reinstalling macOS
  • Updated macOS
  • Restart CoreAudioD
  • Replug Speakers
  • Ran Apple Diagnostics, No Errors
  • Tried Safe Mode
  • Resetting NVRAM & SMC
In my top bar, there's no sound icon. When i go into settings, and click sound, then the Macbook does recognize the speakers. But still won't play any sound through them.
Bad speakers maybe?
And it has no water damage, for anyone wondering.
Update (03/18/25)
Audio board is cooked @livfe
And so is the flex cable
Now it’s confirmed
crwdns2944067:09crwdne2944067:0
Ouch, time to go online shopping :(
That’s liquid damage!
@danj Figured, still don't know how
@hiyxus - doesn’t always due to a spill, it could be humidity (condensation from taking the system from a cooler AC space to a very humid outside).
Nice to know now, was so confused. Well time to find a new audio board and flex cable
crwdns2934275:04crwdne2934275:0
A common issue with headphone jacks is the switches held inside, here’s a deeper dive into the different setups Understanding Audio Jack Switches and Schematics, jump down to Switching Audio Between Speakers and Headphones.
The easiest fix here is just replacing the MacBook Air 13" (Late 2018-Mid 2019) Audio Daughterboard as outlined in this guide MacBook Air 13" Retina Display 2019 Audio Board Replacement
crwdns2886500:0Replace a corroded, dirty, or damaged headphone jack by swapping in an audio daughterboard containing the headphone jack and connectors for one speaker and the Touch ID sensor.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
$119.99
Look at my latest answer, found the problem
Also Appreciate the answer :)
Have you tried using a bluetooth headset and a headphone via the jack port?
A post here might shed some light (Audio board issue)?
crwdns2944067:09crwdne2944067:0:
Yes, i've tried using a bluetooth headset and then it seems to work, also a bluetooth speaker, also workd.
Let me rephrase that
Yes, with a bluetooth headset connected, then i get sound in my headset. When using a bluetooth speaker i get sound in the speaker. But when disconnected then the internal speakers still doesn't wanna work
@hiyxus Same symptoms as in the post I linked to before, check it out, seems likely the Audio Board has develop an issue sadly.....
So what you're saying is that it might be my Audio board that is cooked? Even though there is no water damage, and touch id works?
@hiyxus Cannot be 100% certain, but if your able to follow the steps to diagnose it from that post it may confirm it. These things amongst others can 'go wrong' by themselves unfortunately.
Jonas crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 141
