Why is my screen shaded
my screen has darker areas on both sides of the screen
If this is just a standalone monitor the cost of the bare panel very often kills any chance of the repair working out :-(. Check the label and see but if it's an LG or Samsung LCD there's a good chance the panel cost will be near a nice used one and potentially a brand new monitor of similar quality. I would say 7/10 times the panel cost does you in on displays.
Now if this is a laptop, this looks like a modern T series of the "s" flavor based on the LCD bezel, maybe a early T14. With the ThinkPads you will need to use something like a guitar pick to get the bezel off and then remove 4 screws to get the LCD part number. The good thing with laptops is unless the computer is older like a T480 where parts cost as much as a nice T14 (unless you can get a donor unit with Intune MDM or a BIOS lock with the FHD IPS LCD for very cheap) the older models tend to get expensive to repair vs buying another one, or sometimes a newer computer altogether. Grab the EDID using DumpEDID - Dump EDID information if you want a quick look as it avoids disassembling it if you have a laptop. You run this in command prompt as follows:
Output will look like this:
You can also use MonitorInfoView - View Monitor Information (EDID) if you want a GUI.
Once we know which one you have we can better assess the situation. For a laptop the model will be sufficient to get a starting point. I personally just tend to let the machine go once the processor is older if something major goes like am LCD, especially anything pre 11th gen. The cost tends to creep enough of the time I'll check but I already know.
@nick you got this? Not much sense for both of us to answer. Don't want to confuse the OP. I'll go into comment mode :-)
@oldturkey03 I’ll check the program later. I will have that update soon.
crwdns2947821:0crwdne2947821:0
crwdns2942667:0crwdne2942667:0 198
@georgie3930 we will need to know what exact model your display is. It will also help if you post some good pictures of what your screen shows. Going by your description alone, this sounds like an issue with the backlight or the buffer boards.
Use this guide to add images of your display with your Question Adding images to an existing question
crwdns2934271:0crwdnd2934271:0 oldturkey03 crwdne2934271:0
Hi there, I added some photos i hope this is what you needed and could give me some input. Thank you very much
crwdns2934271:0crwdnd2934271:0 Georgie crwdne2934271:0
@georgie3930 definitely looks like failed LEDs on your backlight strips. Changing that strip should fix this. Of course, this will depend on whatever model your display is. Like my colleague already mentioned, it may be possible to fix this with a new LCD panel depending on what model this is. All a matter of economics
Thank you for answering. I'm curious the two photos i shared with info is this not where i find the model? Is the model on the id plate on the back of the computer or inside? Thanks
@georgie3930 most of those have a sticker on the back of the LCD display but for a laptop it‘ll be more difficult to disassemble. What device does the display belong too?
