This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
How Can I Remove solder from D-Pad?
Before I got it, someone tried to fix something in the motherboard, and put solder in the D-Pad.
Now the up and left direction don't work.
I've tried to skin the solder off, but it feels wrong, Is there anyway to remove the solder completely?
While I don't think you can get 100% of the solder off, you should be able to get it down to a very thin layer on the pad. You'll want to use solder flux and solder wick to absorb as much as possible off the board. You'll still have a silver color to it, but with enough heat and flux, the majority of the solder should come off.
However, keep in mind that the solder may be a result of an attempted fix rather than the cause of the problem. I'm actually wondering if the U and L directions weren't working before, and the previous owner tried to fix that somehow with solder. Those pads are just electrical contacts with a conductive pad sitting above them. When you press the pad down, it bridges the connection between the two halves of the circle, completing the circuit and activating the direction signal you want.
In order to test the signal, all you should have to do is use a conductive object to short the two sides together. Try that for all four pads and verify that the same operation makes all four directions work. If it does, then you may indeed gain something by cleaning off the solder, but if only the D and R pads work that way then there's something else wrong.
Take a look at doing that and see what happens, then come on back and tell us the result.
I´ve just checked all the buttons, and in the selection of your nickname, as I said Up and Left don't work, but when selecting the date the up arrow suddenly starts working, but doesn't stop, and the left button doesn't react.
Checking past the configuration, entering pictochat, the up arrow activates and, again doesn't stop, left still dead.
fernangamer070 :D crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 81
